RE: Diff Problem
The meshing of the gears seems to be fine, the gears were put in the same way they came out and there was to pieces left over. The motor is fine and there is no slop between the clutch bell and the flywheel. The problem appears to be between the flywheel and the links from the centre to the front and back diffs, thanks
