RE: Pentathlon Build Thread
I forgot to mention about the Coverite film. this stuf is easy to use, shrinks nicely and adheres just fine to the surface. here is the down sides.
i would not coer open areas with it, not enough surface srength.
if you get it a bit to hot it clouds as the color is absorbed into the wood.
it is so thin that even a hair from a cat can stand out under the covering, yes a piece of kitty with be with her always.
If you are fine with that, it is great, i wil use it again if weight is a factor in future builds.
o yeah, and if you think you have done an mazing jb prepping the wing .. like i had, it was the best prep had ever done, you shoud see the flaws, because it is so lite it conforms to EVERYTHING.. hehehe.. oh well, i am an amateur. it will be fine.
Chuck
