RCU Forums - View Single Post - FALCON HEAD/ CONTROL ROD PROBLEM
Old 04-10-2007 | 07:28 PM
Gary Morris's Avatar
Gary Morris
Default RE: FALCON HEAD/ CONTROL ROD PROBLEM
Your picture is hard to see exactly what your talking about, could it be that the swash has separated from it's bearing? If so, squeeze it back together and put a tiny drop of CA on the bearing outer race so it can't pull up again. If this isn't the problem then you need to either get a better picture, preferably in outdoor lighting or, with a flash.
Gary
