RE: OFFICAL TIPS AND TRICKS THREAD
Here's a good trick that I've found out that works well. If your piston is getting stuck at TDC during the break in process, or if you have a large displacement engine which is very tough to start, drop 3-5 drops of light viscosity 3 in 1 oil (found at ATV/mcycle shops). Pull the starter a few times and it'll turn over as smooth as silk.
