RCU Forums - View Single Post - Pentathlon by the numbers
Old 04-10-2007 | 10:46 PM
flyintexan's Avatar
flyintexan
Default RE: Pentathlon by the numbers
Step 2
Sheeting the foam parts. I prefer to do this early on for a couple of reasons. The most important, being that the sheeting process can take up a good bit of workspace. Those with a big shop (and/or awesome shop like hanglider) can afford to do this while building on the wood fuse frame....read envy here.
Those that purchase the kit with all of the 1/16" sheeting will need to inpsect the sheeting and begin truing the edges of these sheets. I normally use a long straight edge and a sharp razor. You can also setup a straight edge sanding jig to do the job.
-mark
ID:	661682   Click image for larger version
