RCU Forums - View Single Post - 2 STROKE TO 4 STROKE CONVERSION
Old 04-11-2007 | 06:54 AM
Sport_Pilot's Avatar
Sport_Pilot
Default RE: 2 STROKE TO 4 STROKE CONVERSION
ORIGINAL: mando
Larger diameter prop = more thrust ?
With the height of the front of the airframe that I have, looks like I could comfortably mount up to a 16" diameter prop. But with engine size compatibility for this plane I would only be allowed a 13"-14" prop.
Mando..........
And if you are turning both props at the same RPM the higher pitched prop will have more thrust.
