Name that engine
121/1C is a 5.8--121/1B is a 5.2..49ZN2 is a 4.2..47ZN is a 3.7..
You already have the best crank possible..The rear shaft extension is sometimes used for a spring starter when the engine is run with the stock magneto ignition..It is of no use when electronic ignition is used....
