RCU Forums - View Single Post - Turbo Reg problem.
Old 04-11-2007 | 11:46 AM
SteveD-RCU's Avatar
SteveD-RCU
Default Turbo Reg problem.
I think a may have made a mistake trying to charge 2 Fromenco 7.4 Lithium Ions through my Turbo Reg that I just got.Yes I did read the warnings,but I mistakenly assumed my Accu-Cycle Elite would be ok to do the job.It seemed to be chargeing both alright for a few minutes and then one side shut down .The fail safe switch got hot and so I shut down the charger.
So now when I fire everything up,it all appears to work ok except the output voltage is only 4.8 and I can't get it any higher.The fan will slow down and speed up when you adjust it but the output appears the same.Is my regulator toast?Why can't a list of suitable chargers be made available for dual charging.Thanks Steve
