Smart-Fly (Quest Engineering) Support Forum Support forum for all Smart-Fly products. Equalizers, Batshare, Ignition Cutoff, Regulators.
Turbo Reg problem.
Old 04-11-2007 | 11:46 AM
SteveD-RCU's Avatar
Default Turbo Reg problem.
I think a may have made a mistake trying to charge 2 Fromenco 7.4 Lithium Ions through my Turbo Reg that I just got.Yes I did read the warnings,but I mistakenly assumed my Accu-Cycle Elite would be ok to do the job.It seemed to be chargeing both alright for a few minutes and then one side shut down .The fail safe switch got hot and so I shut down the charger.
So now when I fire everything up,it all appears to work ok except the output voltage is only 4.8 and I can't get it any higher.The fan will slow down and speed up when you adjust it but the output appears the same.Is my regulator toast?Why can't a list of suitable chargers be made available for dual charging.Thanks Steve
Old 04-11-2007 | 12:05 PM
SteveD-RCU's Avatar
Default RE: Turbo Reg problem.
Looks like I was checking the voltage at the receiver end and not the jumper end .. yes I'm getting 6.4 volts into the power expander.Everything looks ok.I just need a different charger.Rookie mistake...Steve
Old 04-11-2007 | 01:49 PM
Hi Steve,
I would love to have a list of chargers that will handle dual batteries with common ground but we cannot buy everyone out there to test. We also are not getting much feedback on which chargers work and which don't. If I can figure out a way to get some input on this I would make up a list. I will see what I can do. Let me know if you have any other questions.
Old 04-17-2007 | 11:28 AM
felker14's Avatar
My Feedback: (50)
1 charger that I know for sure will work charging 2 batteries with common ground is the HughesRC Spectra 4. I also believe the Fromeco Cube will do it. I have a turbo reg with sport expander and the reason I purchaced the Spectra 4 was because it can charge this system setup with no problems.
Old 04-17-2007 | 11:32 AM
Hi,
Thanks for the feedback. I tried to click on the "Contact Us" link on the HughesRC page but got an error. Do you have an e-mail for them? I would like to ask them directly.
Old 04-17-2007 | 01:06 PM
SteveD-RCU's Avatar
I just ordered a Spectra4 thanks abunch.
Old 04-17-2007 | 09:35 PM
felker14's Avatar
My Feedback: (50)
sorry no email but phone # is 1-800-786-0802
Old 04-17-2007 | 10:41 PM
Flying Geezer's Avatar
My Feedback: (14)
Thanks for the heads-up Robert. We'll check the website.
The e-mail address is [email protected]
Felker is correct, you won't have any common ground problems. We use high-side current sensing to eliminate the problem.
Old 04-18-2007 | 09:07 AM
Hi,
Thanks for getting back to me on that. I will make a note of this and probably start a list on my website.
Old 04-18-2007 | 10:58 AM
My Feedback: (14)
The website has been repaired. Thanks for noticing.
