RE: CG Obsession 3d / Saito 180 install
I'm just mounting mine. What I did was cut the central portion of the firewall and bottom sheeting out nearly up to the braces that run back the landing gear box then covered it over with a sloping piece of balsa. This also make an outlet for the cooling air. Hmmm Pic is worth a thousand words...
