RE: Diff Problem
I think I've found my problem. I took apart the centre diff last night and I found that the oring wasn't sitting around the case but had slipped into the gear on the rear side which would explain why the diff was slipping as the gears weren't meshing. Should these orings be replaced every time the diff is opened?
