1. How long have you been drifting/race - about 5 days :P
2. How often do you drift? (times per week/month) - read above
3. Car - Team Losi XXX-S
4. Battery - Venom 3000mAh and a Trinity 3000mAh
5. ESC - Novak/Losi XRS
6. Motor - Trinity "Nervous Breakdown" 19T, Just got a 17t, haven't tested it for drifting
7. Tires - PVC
8. Pinion to Spur Ratio - Pinion is a 24t and spur i think is 40 something i think 42.. not 100%
9. Servo - Whatever comes with the JR XR2i
10. Radio - JR XR2i
11. Upgrades - 17t motor
12. How much did you pay? - $399AU RTR
Subjective Observations:
1. How does it drift? - very smooth and very very responsive
2. What is your runtime? (Range: race/bash) - 20 - 30min roughly
3. Is there a specific surface it performs best? i ise it on my old wooden floor inside and it works great with pvc ultra slide
4. Is the car balanced drifting to the left and right equally, or does it drift to one side easier. - It's very balanced, the xxxs has an awesome chassie
5. Describe the performance characteristics of your car, compare and contrast if possible to other setups you've had or seen first hand. - The Losi XXX-S is a very good set up straight out of the box, you can start drifting with a very small adjustment... just change wheels to PVC
I made one adjustment and went and bought a 16t motor.. havnt tested it for drifting yet but we will see.. it should work
