ORIGINAL: sharpshooterkev
Ok, I did what you said and the servo still started spazzing, I also noticed that when I push the screw on the servo arm it also starts to spazzing, and when I do the same thing to the other servos it dosent do anything. Dose this mean that the servo is bad? Have you ever heard of this happing?
I'd say if you took your 'bad' servo, and swapped channels with it, and it still acts wierd, it's bad. Further, if you touch it, and it fails at ALL, it's bad, period. Contact the vendor you purchased it through, and explain exactly what you did, and they shold understand and either ship you a new servo, or give you a whole new bird.
Personally, I'm all for twisting people's arms and DEMANDING a whole new bird for the fear that more components might also be bad.. (i.e. bad batch of servos, etc)
Best of Luck.
