RCU Forums - View Single Post - Throttle trim hover advise
Old 04-14-2007 | 08:32 AM
imadot
Default RE: Throttle trim hover advise
An off the wall thought on heli throttle adjustment for hovering and motor kill. The problem is a need for a more accessable throttle trim adjustment. What about a thin carbon tube cut 1/2"and glued or epoxy to the trim slider so that you can bump it up or down with just the tip of your fingers. Throttle trim is such an critical element to smooth flying. My last flight was a yoyo affair.
thanks
