RE: Lift Meister
Hi Bob,
Yes, the instructions they are pretty poor.
I printed them off of the website, and they were 100% better.
I was going to post a link to it here but now when you try to open the manual on the website it takes you back to the home page[:@]
On Wes' plane we sanded down the wooden dihedral brace and used the wooden one and the aluminum one together.
I don't know about anyone else, but on Wes' plane the blocks inside the wing, near the aileron servos that the strut's fasten to were only glued the the cap strips. we had to cut away the covering, reglue the block (also added a piece of 1/8" ply for support) and recover the hole. (Very poor design in my opinion)[>:] The Strut supports in the wing should have been pre drilled, so you could find them.
The one I have may go to the swapmeet, or I will probably build a new wing using wing tubes and take out the dihedral.
Gary
