RCU Forums - View Single Post - Hitec Receiver
Old 04-14-2007 | 06:01 PM
jdetray's Avatar
jdetray
Default RE: Hitec Receiver
Hi Badger -
Your Hitec Micro 05S will work with your JR transmitter. You don't have to worry about the shift, because the Micro 05S automatically detects the shift of the transmitter and selects the correct shift.
However, the receiver needs the proper Hitec crystal on the same channel as your transmitter. You can not use a JR crystal in the Hitec receiver. [link=http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXPX96**&P=V]Here is the correct crystal.[/link] Be sure to get the same channel as your transmitter!
Get the proper Hitec crystal for the receiver, and you should be all set.
- Jeff
