Assuming you have your transmitter programmed.............turn the transmitter on first, then the receiver and wait for the gyro to initialize, make sure your throttle is all the way down, activate your throttle hold if you have it set up, then put the glow starter on the plug, make sure the fuel line is unclamped and activate the starter and the engine should fire up. Once the engine is running take the glow starter off.
If your transmitter is not programmed, dont start the heli!!!!
Thanks for this help helimedic!!
Finally i can start the Engine
But I detect Leak fuel in the muffler during the motor was running as shown in the picture. Looks like some part of fuel does not burned totally
am using Wildcat Helimax (30% Nitro @ 18% Sinthetic oil). is correct this fuel? or need to do some calibrations with in the motor?
thanks again!
