Venture 60 - First build
Hi.
I've started my first build, a Venture 60 ( [link=http://www.btemodels.com/venture.html]see it here [/link] ).
I've completed the wings. I've added the dual ailerons, an option that can be added to the original kit.
My question:
I plan on leaving the servos in the wing when I cover. It seems like it will be very difficult to string the servo wires throught the holes in the ribs once the wing is covered, so I plan on leaving the servo installed. I put a little brace around the servos, so they are tucked into the wing and will not interfer with the covering.
Will this cause any problems when I'm covering the wing? The heat from the heat gun won't melt the servo wire, will it?
