RE: servo connections
actually I was going through my box of misc. bolts looking for a bolt and found one. I have another question though, In the front of the same servo the 2 screws cracked the balsa because I didn't use pilot holes first. The cracks ar minor and stop before they reach the outside part of the mount. I put 1 or 2 drops of thin CA on each of the cracks. Will this be ok? The plane is the Top Flite P-47, 63" wing span.
Thanks again, Dave Trimmer
Edit: If you check out the first pic I posted above you can see the cracks before the CA was aplied
