RCU Forums - View Single Post - servo connections
Old 04-17-2007 | 02:25 PM
bruce88123
Default RE: servo connections
ORIGINAL: bigtim
dave the aileron pushrods have alot of torque requirements so you need to remove the servo and clamp re-glue the servo rail and then drill pilot holes for the screws after you screw the screws in then a drop of CA to harden the screw threads.
This being the beginner forum I MUST point out that you need to remove the screws before adding the CA otherwise the screws will NEVER come loose again. bigtim has the right idea but forgot the audience.
I like to drill, add thin CA, let dry thoroughly, install and remove screw, thin CA again and let dry overnight before installing screws again. NO accelerator.
