RCU Forums - View Single Post - Su-Do .60 so far
Old 02-24-2002 | 03:56 AM
wgeffon
Default Su-Do .60 so far
Chris,
Hmm. Tough question.
I would say definately not a first or second kit. If all someone is used to is Sig or GP kits (where they spoon-feed you in the instructions) this isnt a good kit at all. You really need to be able to evaluate the whole plane as its going together making sure you dont screw yourself later. You need to really think about stuff like, If I do ....... now am I going to be able to do ............ later.
You have to be able to do things on your own and not rely on the instructions.
The plans are hard to read. Lines are where they shouldnt be and some lines that should be there aren't. The wood pretty much sucked. Example, hold two 5/16 square pieces together and they arent the same size. Close, but not exact.
Sheeting was warped. Some of the die cutting on the lite-ply wasnt even halfway through the sheet.
It will all be worth it once its in the air. They hover extremely well. SUPER stable. Reminds me of some of the planes out there for G2.
Should be done in a week or so.
