RCU Forums - View Single Post - Engine temps
Thread: Engine temps
Old 04-18-2007 | 08:25 AM
Rcpilot's Avatar
Rcpilot
My Feedback: (78)
Default RE: Engine temps
Your making it too hard.
Mix up your oil and fuel. Don't use some rediculously lean ratio like 100:1. Mix it up at 40:1 or 50:1.
Tune it and Fly it.
Checking your head temps while it's sitting on the ground running under a heavy static load is NOT going to give an accurate reading. Thats completely different than the temps when it's moving through the air.
If it ain't broke--don't fix it. Put oil in the fuel and fly it. There's been a zillion G23 engines run long before you and I were flying model airplanes. Not too many of those guys had infrared temp guns. They just went flying.
