RCU Forums - View Single Post - Fuel changes
Thread: Fuel changes
Old 04-18-2007 | 07:05 PM
Troy Newman
Default RE: Fuel changes
Yes richen it up and re-peak it then back off 300rpm from the peak setting.
Switching from a 20/20 fuel to the 30% heli fuel you may need to open the HS needle maybe 1/4 to 3/8 turn richer setting than on the 20% nitro.
This is one of the reasons the 30% is some much better is it gives more fuel flow through the engine. This mean more oil, and more oil means more cooling.
It is common for the engines to run much cooler and more consitent when going to a higher nitro.
The 2 stroke 45 I don't really have a huge amount of experience with it on 30% heli fuel. you may look to a slightly different glow plug. OS #8 is a good one on smaller 2 strokes. It has just been a long time since I ran those small engines.
Troy Newman
Team YS Performance
