Any of you guys ever heard of Pie R squared?
Volume of a cylinder is Area x height.
Area of a circle is as follows:
Area = Radius squared x pie
Radius x Radius x 3.14 = area
Radius is 1/2 diameter.
If you had a 3.25" bore and a 5" stroke:
Radius = 1.625
1.625 x 1.625 = 2.640625
Now take that and multiply it by 3.14
2.640625 x 3.14 = 8.294916 <<<<<<<thats the area of the piston
Now multiply that by the stroke:
8.294916 x 5 = 41.47 cubic inches
____________________________________________
350 Chevy
3.5 bore
1.75 x 1.75 = 3.0625
3.0625 x 3.14 = 9.61625 <<<<<area of the piston
9.61625 x 4 = 38.465
38.465 x 8 cylinders = 307.72
Your 350 doesn't have a 4" stroke. In fact, it has a 4" bore and a 3.5" stroke
Let's do the math on that
2 x 2 = 4
4 x 3.14 = 12.56
12.56 x 3.5 = 43.96 cubic inches per cylinder
43.96 x 8 = 351.68
You go the same number as me, but you skipped the step about radius squared. It just happens that 1/2 the diameter of the 4" bore is 2 and when you take 2 (radius) x 2 you end up with 4 again. [:-] The rest of your math is correct.
But, it's still only a 3.5" stroke. 4" bore.
