Stihl identification
Old 04-18-2007 | 12:01 PM
Default Stihl identification
Can anyone tell me how to ID my Stihl...it has no markings of any kind.
Also, anybody done a conversion on one of these?
Planing on going gas/glow
Old 04-18-2007 | 01:33 PM
Default RE: Stihl identification
where are those numbers you gave me to look up[?
Old 04-18-2007 | 04:27 PM
I DUNNNO...GAVE EM TO YOU
Old 04-18-2007 | 06:20 PM
Rcpilot's Avatar
My Feedback: (78)
Pull the muffler off.
Pull the spark plug.
Measure the bore through the muffler port.
Measure the stroke through the plug hole.
Volume = Area of piston x stroke.
Taa Daaaaaaa!!!
Old 04-18-2007 | 06:49 PM
av8tor1977's Avatar
Formula is:
(Bore x Bore x stroke) x .7854 = displacement
Measured in inches, that will give you cubic inches. To get cc, divide by .061.
Old 04-18-2007 | 10:06 PM
KI8FR's Avatar
bore x strok x 3.14 = displacement. But the post before will all work too.. Just wanted to put mine in lol
Old 04-18-2007 | 10:11 PM
buck1856's Avatar
My Feedback: (49)
heres an example poulan/30mm bore,30mm stroke.
round pie to 3.14-divide bore by 2 or squared
15x15x3.14=706.57
706.57mmx30mm stroke=21195 cubic mms
theres 10mm in 1 cm.
this engine would be 21.195cc"s.
i just completed a 28cc (27.2)actual stihl with ch ign but will run it this weekend when my hub arrives.im also doing the 26cc wich is( 25.9)actual.
the 28cc came from a FS-46.
the 26cc came from a BG-75
ill post a pic of the 28 when hub arrives
Old 04-18-2007 | 10:52 PM
KI8FR's Avatar
I did mine like I would a v8.. Like a 351
bore 4" stroke 3.50"
4x3.50x3.14=43.9x8 selenders give you. 351.68
Sorry about that. lol
Old 04-18-2007 | 11:22 PM
Rcpilot's Avatar
My Feedback: (78)
Any of you guys ever heard of Pie R squared?
Volume of a cylinder is Area x height.
Area of a circle is as follows:
Area = Radius squared x pie
Radius x Radius x 3.14 = area
Radius is 1/2 diameter.
If you had a 3.25" bore and a 5" stroke:
Radius = 1.625
1.625 x 1.625 = 2.640625
Now take that and multiply it by 3.14
2.640625 x 3.14 = 8.294916 <<<<<<<thats the area of the piston
Now multiply that by the stroke:
8.294916 x 5 = 41.47 cubic inches
____________________________________________
350 Chevy
3.5 bore
1.75 x 1.75 = 3.0625
3.0625 x 3.14 = 9.61625 <<<<<area of the piston
9.61625 x 4 = 38.465
38.465 x 8 cylinders = 307.72
Your 350 doesn't have a 4" stroke. In fact, it has a 4" bore and a 3.5" stroke
Let's do the math on that
2 x 2 = 4
4 x 3.14 = 12.56
12.56 x 3.5 = 43.96 cubic inches per cylinder
43.96 x 8 = 351.68
You go the same number as me, but you skipped the step about radius squared. It just happens that 1/2 the diameter of the 4" bore is 2 and when you take 2 (radius) x 2 you end up with 4 again. [:-] The rest of your math is correct.
But, it's still only a 3.5" stroke. 4" bore.
Old 04-19-2007 | 12:00 AM
KI8FR's Avatar
Mhhhhhhhh.... I see that.. I forgot that part.. It has been to long that I had to do that.. lol
but I did say that the bore was 4" and the stroke is 3.50... In fact the stroke is 3.498+or-002
lol
Thanks for the info.
Paul
Old 04-19-2007 | 07:17 AM
av8tor1977's Avatar
YEP...
AV8TOR
Old 04-19-2007 | 11:31 AM
My Feedback: (29)
Upload a picture and maybe someone will recognize it.
Dave
Old 04-19-2007 | 12:26 PM
thanks guys, will put pic up when get a chance
Old 04-19-2007 | 03:17 PM
My Feedback: (40)
Isn't that "Pi" R squared?
Old 04-19-2007 | 04:33 PM
Ralphbf's Avatar
My Feedback: (27)
Pie are round, sheet cakes are square.
Old 04-19-2007 | 05:32 PM
My Feedback: (29)
Entered in error.
Old 04-30-2007 | 02:37 PM
Its a stihl 44fs, 30.6 cc thanks guys...pass the pie ralph
Old 04-30-2007 | 02:47 PM
Hey Rooster Set the plug at .030, mix the fuel at 50:1 and prop it to turn 7500 an stick it in a 120 size plane and no not big enough for your yak 54. you want at least a 46 for that bird.
