RCU Forums - View Single Post - My Condor Pro Problems
Old 04-20-2007 | 04:10 AM
fanofnitro
Default RE: My Condor Pro Problems
I got the electric starter on tuesday, only to find that my one-way bearing is 12mm and the case fits 14mm only. however i got a piece of brass, cut it into six small pieces and stuffed them in between the bearing and case. It worked perfectly!! Im still waiting on the suspension arms, ******** delivery seems to be very slow....[&o][&o][&o] I have made the bumper, its kinda mushroom shaped, il post a pic later. i must still mount it, using 3 m6 countersunk nuts to mount it under the chassis as the shock tower is plastic. Its made out of strong plastic....... Hpefully itl work.... I havent tried starting it since.........
