RCU Forums - View Single Post - DA 50 Underpowered
Old 04-20-2007 | 06:41 AM
kevinbell's Avatar
kevinbell
Default RE: DA 50 Underpowered
Where did you get that manifold/header from? It looks nice. I've had a look at BMB, MTW, Krumscheid systems, there doesn't ssem to be a nice curved pipe like Dick's. Is the length of the header critical like small 2 stroke engines with tuned pipes? The total length is a problem, the wing tube is in the way. The total distance from the engine exhaust port to the tube is 400mm.
Here's a photo before I cut anything, Ive moved the rudder servo closer to the tail. There's a shroud around the exhaust and the fuel tank is above it.
Kevin
ID:	668522   Click image for larger version
ID:	668523   Click image for larger version
ID:	668524   Click image for larger version
ID:	668525   Click image for larger version
ID:	668526   Click image for larger version
ID:	668527   Click image for larger version
