RE: Correct fuel tank installation--help
I am sure I am in the minority here but I never seal the hole in the firewall as long as you coat the tank compartment with thinned epoxy some 30 min epoxy with alcohol, brushed into the tank compartment to fuel proof it your fine replacing lines is simpler most of the slime is on the outside of the fuse any way.
