Hi Rajul, I just got my aerofly Deluxe (Invoice 624977) and I seem to have the same problem with the interface, at startup I get the same "Aerofly is unable to locate the USB interface cable. Please plug the interface cable into a free USB port" message.
Please help!!
This is my TM log:
tm: Library Version 4.3, Copyright (C) 1999-2006, IPACS
tm:
http://www.ipacs.de
tmsystem: init random with 58449
tmsystem: cpu type=(nlogical=1) (nphysical=1) (no hyper-threading)
tmsystem: cpu=0 Mhz
tmsystem: memory=(physical=255MB, avail=98MB) (virtual=2047MB, avail=1670MB)
tmsystem: operating system=Microsoft Windows XP Version 5.1 Service Pack 2 (Build 2600) Service Pack: Service Pack 2 (Build 2600)
loading font v2 texture/fontuni.tff=(2048x2048) (h=16) (nc=65536) (split=1) ok
tmgl: loading mouse texture/mouse.tmt=ok
tmprogram: AeroFly Professional Deluxe Version 1.9.7.11, Copyright © 1998-2007 IPACS
loading configfile config/main.mcf=ok
loading player configfile config/player1.mcf=ok
loading player configfile config/player2.mcf=ok
directsound: register sound sound/beep.wav=ok
directsound: register sound sound/balloon.wav=ok
directsound: register sound sound/crash.wav=ok
directsound: register sound sound/splash.wav=ok
directsound: register sound sound/glider.wav=ok
directsound: register sound sound/glider2.wav=ok
tmgl: failed to load texture texture/cockpitmain.bmp
afdesign: init ok
directinput: init=ok
tmsystem: current monitor frequency=60
init window=(window=800x600) (screen=1280x720) (32bpp) (60Hz) (window)
directsound: init=(speakerconfig=unknown) (certified) (cont.rate) (primary 16bit) (samplerates 8000,48000) (1 hwbuffers) (0 hwbytes)
init pixelformat=ok
gl: vendor=NVIDIA Corporation, renderer=GeForce4 MX 420/AGP/SSE/3DNOW!, version=1.5.0, opengl version=1.5
gl: (viewport=4096x4096) (texturesize=2048) (stencil=8)
gl: extensions=GL_ARB_imaging GL_ARB_multitexture GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_window_pos GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_paletted_texture GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shared_texture_palette GL_EXT_stencil_wrap GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_vertex_array GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_fence GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_register_combiners GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_NV_texture_rectangle GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_SGIS_generate_mipmap GL_SGIS_multitexture GL_SGIS_texture_lod GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
wgl: extensions=WGL_ARB_buffer_region WGL_ARB_extensions_string WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_render_texture WGL_EXT_extensions_string WGL_EXT_swap_control WGL_NV_render_texture_rectangle WGL_ARB_make_current_read
gl: extensions=(lockarrays) (multitexture) (pointparameter) (vertexbufferobject) (paletted texture) (separate color) (anisotropic filter of 2.00) (compressed texture) (cubemaps)
wgl: extensions=(wglpixelformat) (wglrendertexture) (swapcontrol)
tmsystem: fullscreen modes=(rj-640x480x16x60) (rj-640x480x16x70) (rj-640x480x16x72) (rj-640x480x16x75) (rj-720x480x16x60) (rj-720x576x16x60) (800x600x16x60) (rj-800x600x16x70) (rj-800x600x16x72) (rj-800x600x16x75) (rj-848x480x16x60) (rj-848x480x16x70) (rj-848x480x16x72) (rj-848x480x16x75) (1024x768x16x60) (rj-1024x768x16x70) (rj-1024x768x16x72) (rj-1024x768x16x75) (1152x864x16x60) (rj-1152x864x16x70) (rj-1152x864x16x72) (rj-1152x864x16x75) (1280x720x16x60) (1280x768x16x60) (1280x960x16x60) (1280x1024x16x60) (rj-640x480x32x60) (rj-640x480x32x70) (rj-640x480x32x72) (rj-640x480x32x75) (rj-720x480x32x60) (rj-720x576x32x60) (rj-800x600x32x70) (rj-800x600x32x72) (rj-800x600x32x75) (rj-848x480x32x60) (rj-848x480x32x70) (rj-848x480x32x72) (rj-848x480x32x75) (rj-1024x768x32x70) (rj-1024x768x32x72) (rj-1024x768x32x75) (rj-1152x864x32x70) (rj-1152x864x32x72) (rj-1152x864x32x75)
directinput: searching joysticks=(acquire failed) none
tminput: searching for input devices...(1)
tmsystem: searching usb interface (0) 0=unable to open interface device
tmsystem: searching usb interface (1) 0=unable to open interface device
tmsystem: searching usb interface (0) 0=unable to open joystick device
tmsystem: searching usb interface (1) 0=unable to open joystick device
tminput: 0 devices found
tminput: searching for input devices...(2)
sim: loading scenery scenery/winzeln.geo...
sim: 1 objects 0 dynobjects
sim: start position 1 (not for helicopter)
sim: start position 2 (not for helicopter)
sim: start position 3 (not for helicopter)
sim: start position 4 (not for airplanes)
sim: load texture grid 5x5 (compress=1) named winzeln/winzeln=(5x5) (24x13) (72.00 36.00) (3.00 3.00)
sim: sphere params(3)=-1.5000 0.0000 -0.7000
sim: loading ground object scenery/winzeln/winzeln.obj=ok
sim: loading time=22341524 mus
tmcollision: 1604 triangles using 205312 bytes
tmcollision: omin=(-5000.0,-5000.0,-2.1) omax=(5000.0,5000.0,59.6) octmin=(100.0,100.0,100.0)
tmcollision: otnodes=61 otendnodes=31 otdepth=14 otlistareas=23746
tmcollision: otnmaxareas=370 otnavgareas=67 otnminsize=(78.125,78.125,61.766)
tmcollision: otareas=2088 mem=213664
tmcollision: 61 octrees, using 9272 bytes
tmcollision: total mem=222936 bytes
tmcollision: time=0.11s
tmcolldynamic: no dynamic objects or triangles
sim: loading aircraft 1 christeneagle...
tmdairfoil: loading naca0015 ok
tmdairfoil: loading flat ok
tmdairfoil: loading naca0009 ok
directsound: register sound sound/g15-3000.wav=ok
directsound: register sound sound/g15-5000.wav=ok
directsound: register sound sound/g15-10000.wav=ok
generating shadow christeneagleshadow0=radius=2.13 bbmin=(-1.28 -1.28 -0.46) bbmax=(1.28 1.28 0.27)
sim: creating blurr=Propeller
tmmusic: off
