RE: What glue for sheeting???
if you are sheeting both top and bottom of the wing,i use ca on one side because you have access to the underside to apply the ca then white/wood glue (i use titebond) on the other side and as said here tape pins ect.wood glue tends to cause the sheeting to bow some so make sure you have it pinned taped weighted or whatever is needed to hold it down.
