What glue for sheeting???
Hey,
What glue do u guys use for sheeting balsa to an open frame wing? Some guys have told me CA thick and other Great planes wood glue.
Cheers
Cheers
My Feedback: (15)
VA
if you are sheeting both top and bottom of the wing,i use ca on one side because you have access to the underside to apply the ca then white/wood glue (i use titebond) on the other side and as said here tape pins ect.wood glue tends to cause the sheeting to bow some so make sure you have it pinned taped weighted or whatever is needed to hold it down.
Yea, thanks for the help guys.
Im just scratch building a c152 and i was just sheeting the flaps.
Just another question, would a HS-81 have enough torque to control the throttle on a OS46AX?
Cheers
Cheers
I use either Elmer's Carpenters Glue or Tite Bond II for almost all my building. Aliphatic resin glues sand a lot better than CA will and give you time to work.
An HS-81 will work, even an HS-55 will work fine for the throttle servo since there is no real torque required to rotate the throttle barrel.
Hogflyer
Hogflyer
Ok Bruce why not white glue? after a crash that did not involve a wing my daughter jumped on the wing and jumped off, the wing flattened out and sprung back up. used white glue on everything except the spars.
Hey,
Thanks for all the info!!!
Once the plane is finished, what methods are there of covering it??
The 3 that i know of are glassing, fabric and dope, and monokote. I dont like monokote cause it always wrinkles in the sun. I want a covering that is easy to put on and that i can spray paint with out worrying about the paint coming off. Ive been told the glassing is hard and adds a bit of weight so i dont really want to do that.
Cheers
Cheers
if monokote is applied correctly it wont wrinkle in the sun. it may lossen a bit the first trip to the field but a heat gun will tighten it up.
Monokote is by far the easiest.
You can also try a low temp covering like Ultracoat.
As for gluing skins onto a frame, there's the iron on technique which works quite well. Apply an even coat of alphatic resin or PVA glue (carpenters glue) to all the ribs and spars. Apply an even coat to the skins where it will meet the ribs and spars. Let the glue dry BEFORE assembly (about an hour). Place the skin into position and use a covering iron to "reactivate" the glue. Once the glue is heated, the bond is almost instant like contact cement.
Scott
Scott
I used a small servo on a 60 size plane and yes it will easily have enough torque to operate but I had a hard time getting enough throw to get the full range out of the throttle due to the short servo arms. I managed to make a longer arm but I won't use small servos again, not worth it to me!! [>:]
ORIGINAL: jetmech05
MB, CANADA
Collect some old phone books from your friends; they make great weights for sheeting. I use weldbond glue for nearly everything.
ok bruce thats different than white glue should not be used. the last kit i did was over 2 1/2 years old with well over 150 flights on her. never had a problem.
i will only use monocote on an airplane im building becuase if i crash or my retracts stick, its easy to patch fiber glas would hold but paint may crack and the doping could break, rip and its harder to repair, my friend lost hi landing gear on hid doped plane and it cost him $560 to fic the covering becuase he couldnt do it himself. My opinion tho.
My Feedback: (13)
sheeted the top of my P-47 wing with tite bond what a pain in the rear, thick or med CA works well for me.
after sheeting one side I had to go back and reglue a bunch of areas.
the other side came out perfect using med. CA all the compound curves came out perfect unlike the other side which was a mess all distorted and full of pin holes a learning experience tite bond is a great adhesive, I am not so sure for where you need fast tack and a solid grab like sheeting a wing.
if you are planking a fuse then your better off using tite bond/wt.glue where you have to sand alot, CA doesn't sand unless you break out the heavy grit paper.
its about building style I would think.
GA
I like the original Titebond glue over the Titebond II, as the Titebond II sands a little rubbery. Both are grate products, I just prefer the original.
