RCU Forums - View Single Post - A question about tail wheel assemblies
Old 04-21-2007 | 07:37 PM
bbbair
Default RE: A question about tail wheel assemblies
Hmmm I'm not too sure why you're ordering a new rudder if you just broke the tail wheel... is there more extensive damage to the rudder??
Rudders are just a balsa wood frame placed together with CA glue and a couple of supports and then covered with your choice of covering material. The average Rudder can be put together in 1/2 hour or so; covering to folow. (See attachment)
The Wheel assembly is just wire and very inexpensive, start bending until you get something that you like (see same attachment) - throw away the first 5-10 trials (tell no one... )
To remove an old hinge take out your Dremel tool and attach a rotory cutting blade. A couple of precise passes will excise the old hinges. If the new slot is too large for your new hinge; fill in the hole with a thin slice of balsa and cut a new slot for the hinge.
Your problem can be solved in one evening in your workshop for under a dollar.
Good Luck
