How does thrust compare to the APC 15x4w? I found the 15" gave more thrust than the 14". I've actually thought about using the 14x5 Pro Zinger just because I would like a bit more airspeed. Some sandpaper should make it a great prop. I've heard modified Pro Zingers are hard to beat, that's why I'm trying it.
ORIGINAL: drumbum
Actually the 14x5 zinger is the ticket. you guys should try that. very little difference in airspeed over the APC. but the thrust and spool up are no contest.
