RE: Engine and water spray, what to do?
If water is hitting the prop, it will rob a substantial amoung of power from the engine.... the easiest fix is to install spray rails on the side of the hull to deflect the spray sideways, away from the prop... It the engine is exposed, it doesn't hurt to have an air filter (Bru-line makes some), but it will not protect against a heavy soaking of water.....
