RCU Forums - View Single Post - Problem with a pin switch??
Old 04-23-2007 | 11:38 AM
3Dreaming
Default RE: Problem with a pin switch??
OK I checked and I was not getting the pin in all the way. By supporting the rear of the switch I was able to push it in all the way. Besides polishing the end of the pin to make it more rounded, (which I already did) is there anything else that can be done to help? I have some Dow Corning DC4 electrical silicone compound, would it be OK to lubricate it with that? My switch is mounted in balsa sheeted foam, and does not have a lot of extra support. Tom
