Problem with a pin switch??
IL,
I'm having problems with my pin switch. I am using a Super Regulator with a pin switch. There have been some times when I turn my transmitter on I find the receiver already has power with the pin in the switch. Normally I don't hear any noise coming from the airplane, but today several time I would hear the servos buzzing from the wind pushing on the control surfaces. I would go to check the switch, and the pin seems to be in place. I'm I doing something wrong, or do I have a bad switch? Thanks, Tom
My Feedback: (12)
MS
I use the same switch, When it was new, it was a little tough pushing the pin past the activation point.....it got easier after more usage. Make sure the pin goes into the switch 5/8"
Along these same lines, I am just a bit curious about MTBF (life expectancy) for this switch....One plane has over 400 flights on it!
CO
I agree with PropStricker, I've found mine activates in the last 1/16 to 1/8 inch, and as it's still new, it's kinda hard to push in the last little bit.
Be carefull and try pushing it in a little further.
BP
BP
AZ
Hi,
The common problem is not pushing the pin in far enough. There is a slight detent early but you have to push past that. Let me know if you are still having problems.
IL,
OK I checked and I was not getting the pin in all the way. By supporting the rear of the switch I was able to push it in all the way. Besides polishing the end of the pin to make it more rounded, (which I already did) is there anything else that can be done to help? I have some Dow Corning DC4 electrical silicone compound, would it be OK to lubricate it with that? My switch is mounted in balsa sheeted foam, and does not have a lot of extra support. Tom
AZ
Hi,
You might try grinding the end of the pin so there is more of a bevel all the way around. Pointier would be better than rounded. I don't think the silicon compound will do anything, in fact, it might make it less electrically conductive in the off position which would not be good.
AZ
I will get you a replacement out Monday. Send me your address and phone number at [email protected].
