RCU Forums - View Single Post - Problem with a pin switch??
Old 04-23-2007 | 11:45 AM
rrritchey
Default RE: Problem with a pin switch??
Hi,
You might try grinding the end of the pin so there is more of a bevel all the way around. Pointier would be better than rounded. I don't think the silicon compound will do anything, in fact, it might make it less electrically conductive in the off position which would not be good.
