RE: Comp ARF Flash update
On my second plane I used the Behotec gear with the Behotec nose gear, already trailing link, and the large set of trailing links from Todd at Dreamworks. # DW-PLLGMAIN
The hole in these are .250 instead of 6mm so you will have to drill out the gear to .250 ! Very easy to do!! You will also have to cut off the axles depending on your wheels! Again, very easy to do. You will have to relieve the landing gear opening in the wing to fit the shape of the new struts. I sprayed some of the expanding foam into the opening and then cut it out so you really can't tell any difference. Depending on how rough your field is you will have to replace the springs from time to time. I have probably 50 flights on my first one and they are just now getting a little weak.
