RCU Forums - View Single Post - Comp ARF Flash update
Old 04-23-2007 | 12:49 PM
  #412
JetCatJimmy's Avatar
JetCatJimmy
Default RE: Comp ARF Flash update
ORIGINAL: quist
Are any of you Flash owners have any heat issues in fuse above the tailpipe?
Yes. my Flash, you've seen it Tony, was VERY hot to the touch above the thrust tube. It almost melted through my stab extensions. I put ceramic blanket covered in foil along the top half ALL the way down. It was a pain, since you have to remove the thrust tube and bellmouth completely. But you'll be glad you did. Make sure to use foil! I also wrapped the extensions in foil tape to reflect as much heat as possible. It did change my CG a little and had to be fixed, but it's nice and cool now.
