RCU Forums - View Single Post - Axe CP Vibration???!!!!
Old 04-24-2007 | 12:39 AM
osterizer
Default RE: Axe CP Vibration???!!!!
Yes, but you can use couple of finishing nails or grip bolts to hold them in the tray and then clamp them with the 2.5 bridge. they may be off by a fraction of a mm, but no big deal. Be careful to keep the support triangles in the exact same position when you zero it and when you're balancing the blades-- if you let the supports move, it throws off the zero point and you won't get them balanced correctly. I drew datum lines on the surface of my bench to line them up with, but eventually I'm going to get motivated and make a shaft for my TopFlite magnetic balancer so I can use it instead.
