RCU Forums - View Single Post - PROBLEMS with my firebird freedom
Old 04-24-2007 | 04:29 AM
davemac2
Default RE: PROBLEMS with my firebird freedom
can you be a little more specific as to what it is doing and what you have done to try to fix it?
1. Do you know if the batteries are actually getting fully charged and are functioning ok? try running your motor or a spare motor off a pack directly with a prop installed and see how long it will run for.
2. Does it work at half throttle? full throttle? servos responding ok?
3. Is transmitter antenna tight? Is antenna wire on plane intact and undamaged? Have you done a rangle check to see if range has been affected?
4. Is rx/esc in the plane physically damaged in any way?
dave mc
