RCU Forums - View Single Post - JR 9411 centering
Old 04-24-2007 | 10:04 PM
Pattern_is_Fun
Default RE: JR 9411 centering
I have done this on other JR servos.. VERY SENSITIVE as indicated. I filed a 12" pushrod into the "V" shape at the end, bent it 90 degrees to look like an "L", the used the long end to move the centering very slowly. Take out the screw, look down the hole and if you see a slotted screw, you can do it.
sc
