JR 9411 centering
I seem to remember someone telling me one can adjust the neutral position of the 9411. I assume it takes a small screw driver down the center of the output shaft like the old Kraft servos. Anyone know if this is true and how to do it?
Jim O
Jim O
I have done this on other JR servos.. VERY SENSITIVE as indicated. I filed a 12" pushrod into the "V" shape at the end, bent it 90 degrees to look like an "L", the used the long end to move the centering very slowly. Take out the screw, look down the hole and if you see a slotted screw, you can do it.
sc
sc
