RCU Forums - View Single Post - Roybi Ignition Clearance
Old 04-25-2007 | 02:28 PM
davewallace
My Feedback: (29)
Default RE: Roybi Ignition Clearance
Just insert a business card or simular card stock between the magnets and the coil. Tigthen down the coil screws and remove the card. The idea is to get the coil as close a possible to the magnsts without touching. If the flywheel drags on the coil after adjustment, you may have bad shaft bearings.
Dave
