RE: GST 2-3rd gear shift fix
air,
Do you have a gst that you race or run on a track, with a locked center diff?? or is this theory? I have a nemesis with a center lock and this thing does NOT have a slight push!! I can dive that beast into a corner or pitch it around the high side(drift style with the right throttle timing) the best one is a power on exit out of the corner and the truck settles onto its haunches and blasts out of the corner after a slight power entrance into the corner. All this is very controllable and predictable on the genesis series trucks properly setup.
BTW what is your setup?
My point is, there are several people here in the forums that "educate" people about this setup and that setup, when they have never even tried those setups on those trucks. I agree, that usually it "might" cause a push in "some" setups, but unless you have personal experience with it then dont "educate" as as if you do/have. The same goes for the fellas that trash talk a product they have never owned.
Just curious,, not flaming..
Edit:
BTW my nemesis can and will overpower a corner if i'm not careful with the go fast trigger
