RE: Broke another rear diff bevel gear shaft
The Nemesis diffs have a alloy diff case, other wise they are the same. It could be that you put it back together wrong or you are getting a lot of flex in the diffs. I am not sure what else could be the problem, but if it is flex, than the alloy diff case should solve this problem.
