RE: Dave Patrick super cub
i think it is a clevise soldered or threaded the pin end is cut off then a small bolt goes thru one with a hole on each side, many engines will work the two you have are great but from the tread bud started, the engine that had the most talk was the os 1.6 twin 4c, sound and scale power, thanks frank
