RCU Forums - View Single Post - G23 UNRELIABLE. HELP NEEDED!
Old 04-26-2007 | 06:37 PM
khodges
Default RE: G23 UNRELIABLE. HELP NEEDED!
ORIGINAL: flaviosi
I'm using a 16 x8 prop and 25/1 gas/oil. There are no leaks in tank or lines... I'm guessing it's probably a carburator problem?
Flavio
You might try richening your mixture by changing the gas/oil ratio. 32:1 is good to break the engine in; once you've done that you can run it at 40:1 with a good synthetic 2-stroke oil (Amsoil or Klotz). I don't think that's your entire problem, though, sounds like the carb does need some attention
