RE: Problems
I'm guessing that fuel won't go into the carb after it stalls? If that is the case you are having a vapor lock problem, too much heat in the carb body and it boils off the fuelas it gets there. Not necessarily running lean but try richening the HSN an hour or two. Again, if this is the problem make sure you have good air flow to the engine, no mud clod stuck in the fins, etc.
