RE: Dave Patrick super cub
Fossil, the end pieces are aluminum tube from the K&S tubing rack at the LHS. Flatten one end and drill for screw. The wire is threaded one end 4-40 and the screw was just for effect as per pictures of the real one. Slid a short piece of alum tube over and up to screw and all is held in place with ca except where it is bolted. Do you have any pictures you can post here and is it the full wing cub or clipped? BTW anyone needing a new cowl I just found out Fiberglass master has one for the DPM cub for $38.00.
Bud
